Old 02-29-2012, 10:27 AM   #22 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by nlc View Post
More important decision for example is to tell the charger to pass to low current charge mode for balancing, completely stop the charge, tell controller to stop discharging the pack (at a first low voltage threshold for example), and why not cut completely the power by opening the main contactor at a second lower voltage threshold.
From my side I have not finished the development of the master board, because I want to take time to really think it to be perfect for EV usage.
NLC,
Are you going to design your “Master Board” to interface with the ReVolt Controller ?
A new version of the ReVolt Controller PCB that has the BMS master on-board would be very nice! You just directly plug in the distributed BMS slave boards to the new controller.
The ultimate would be an integrated BMS/Controller/Display & Charger?, just add batteries.
-Mark
The Following 2 Users Say Thank You to sawickm For This Useful Post:
mrbigh (02-29-2012), skeeterb (02-29-2012)
