Originally Posted by BHarvey
The other, often overlooked fact of multi-ground strap plugs is that they take up more space in the combustion chamber, and bump compression slightly.
...plus, all those metal straps begin to act like
both a "
heat-sink" and mechanical "
shield" around the central element...two physical events that actually
reduce the chances of proper, reliable, operation!
