Thanks !!! I added additional brackets to the lower edge of the front biulkhead and it appears to be very secure and should prevent the tail from tipping downward. Its raining now so I'll have to test it after it stops raining.
I still have to close up the bottom of the tail . I plan to use some sheet metal around the exhaust but so far the coroplast panels are doing well, no melting or scorching. I also need to get a shorter chain so that I can go with a smaller rear sprocket.
I started working part time and my new job will involve a lot of travel so I need to make as much progress as I can before the The Quail Gathering/Vetter Challenge in May.
