Old 02-29-2012, 08:18 PM   #2 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
I've pondered it, but never attempted it. On a turbodiesel I suspect it would help to reduce the pumping losses, although it should be done in a way to minimize the potentially negative aero effects. On a throttled, naturally aspirated engine I suspect that it might not help that much because the increased intake air density will force the throttle to be more closed, so the pumping losses might actually increase.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
