Old 02-29-2012, 09:22 PM   #45 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by DieselDrewski View Post
I don't need as much air to cool the engine as the original, is there anything there I can take advantage of?
Yes, a grille block will help. Just keep an eye on your coolant temps and/or intake temps to make sure you don't push it too far. A belly pan might be beneficial as well. Well you think about it, it's sort of like driving without the hood, except it's the whole undercarriage.
It would be interesting if you had a removable top version--then you could have made something similar to a aerodynamic pickup bed cap. Depending on how "funky" you mind your vehicle looking, you might be able to fabricate a boat tail that would attach to the back, perhaps via the spare tire mount.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
