Old 02-29-2012, 08:24 PM   #16 (permalink)
CrazyLee
The Beast - '93 Fleetwood Flair includes kitchen sink
90 day: 9.2 mpg (US)
The Bigger Beast - '03 Winnebago Sightseer Motor Home
Calibrating an MPGuino with a JCar module
Originally Posted by bestclimb View Post
does the Jcar module work with the standard Mpguino code or will I need to rework the code?
The Jcar module works with the MPGuino. I have found out that my settings needed changing. the micro-sec/gallon was way off from what I was using.
The regular calibrating method should work well.
To get close I set it very high (Mine went to 40,000,000 to start!) and watched the instant MPG. I kept bringing the micro-sec/gallon down close to what you think what the car MPG should get.
Having a passenger fiddle with the switches to reconfigure the micro-sec/gallon number is a great safety feature! Then you can do it on the run.
After that do an actual fill up calibration. This should only be a two run test if you are close to start with. Follow the instructions on the website.
I hate to burn up that expensive gas!
Tell us how it went.
The Following User Says Thank You to CrazyLee For This Useful Post:
bestclimb (03-01-2012)
