Just to clarify, the MAF based method does work fairly well for most gasoline engines (non lean burn), because AFR is fairly constant. I suspect OBDWiz would work quite well in those applications.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
