Old 03-01-2012, 06:35 PM   #275 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by ps2fixer View Post
Interesting results, what about in gear fuel cut coasting? I think I read it was better than neutral coasting but not as good as engine off coasting.
If you stay in gear you're braking, thus covering less distance.
That makes it less efficient than coasting in neutral.
Coasting in neutral has significantly reduced my fuel consumption - it's now my main way to slow down.
I avidly used DFCO / engine braking before joining ecomodder.
Coasting in neutral or engine off will really add to the benefits of aerodynamic improvements - you'll roll ever further.
