Old 03-01-2012, 06:21 PM   #86 (permalink)
E4ODnut
Old Mech,
If I understand your post correctly you are talking about engine braking, for instance, descending a hill, throttle closed. The theory is that if you open the throttle, engine braking would be reduced?
I agree with that. No theory, just observation. When I am descending a grade, throttle closed, I can shut off my fuel injectors. Minimum manifold pressure (max vacuum), no power developed in the engine. If I open the throttle the injectors will fire again, but, I can use manual control of my idle air valve to imitate a partial throttle opening. If I do this, manifold pressure increases (decrease in vacuum), still no power being produced, but the vehicle speeds up.
Robert
'95 Ford E150 4.9L I6 Megasquirt MS1 Custom MSnS Extra
'92 Winnebago Elante 33 RQ Ford 7.5L V8 Megasquirt MS1 Custom MSnS Extra
'93 Bayliner 3288 Twin Ford 5.8L V8s (351 Windsors) converted to tuned port EFI. Megasquirt MS1 Custom MSnS Extra
