Old 03-01-2012, 07:24 PM   #15 (permalink)
pete c
have been told by truck drivers that the proper way to drive a TD is to be light on the fuel feed. he was adamant about not calling it as throttle seeing as it was not a throttle.
of course this was for driving large semi trucks where power to weight ratios are rather horrible. he said that flooring it meant using lots more fuel for barely measurable increases in acceleration rates. perhaps with a smaller vehicle the gain in acceleration is worth the increase in fuel feed rate.
btw, i was under the impression that modern FI gassers did better with a heavy foot and short shifting. the reason being that fuel/air ratios remain constant even under heavy throttle.
