Old 03-01-2012, 11:14 PM   #3 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
AWM not AEB
the AEB engine was about 150hp but those were not used after about 1999 ,
your engine AWM is good for about 180 hp stock and about 1 bar of boost , stock 1 bar = about 14.7 psi
so
for better FE , why not re install the original software ? your tampered with software is probably not an improvement in anything anyway .
if you have not replaced the timing belt
do it yesterday , when the belt breaks the engine becomes a boat anchor .
never use any oil that is lesser than VW spec 502 , 504 is much better , do not attempt to save money on oil quality
you may be able to use 87 octane top tier fuel
IF you are not driving at WOT , ever . FE may go down due to knock correction ... or not depending on how aggressively you drive
grille block
