Old 03-02-2012, 05:36 PM   #10 (permalink)
aerohead
why
Originally Posted by wheel_of_steel View Post
Even if it is possible to reattatch flow to a bluff surface, why would you want that?
The volt's sharp creases certainly show what chevy's engineers think of that idea.
When its done with suction,each streamline filament is drawn in towards the center of the vehicle,providing 'camber' if you will to the flow field which helps inject energy into the wake,which would otherwise be full-blown turbulence.
Having that transverse force vector really cuts drag.
But I've only seen it done with a pump supplying the suction.And so far,the pump absorbs more energy than is saved with the suction.
It's a second law of thermodynamics entropy thing.
