Originally Posted by drmiller100
you need to find someone with a wideband and see if your engine is really running lean, or the ecu just thinks it is.
i still bet you don't have the 02 sensor wired correctly.
Is it true that once the engine light goes the engine goes to a default (rich), setting?, because my emissions are REALLY bad.
