Old 03-03-2012, 02:02 AM   #6 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
AEB has bolt down coils AWM has push fit coils
the AEB has bolt down coils while the AWM family has push fit coils
the letter designation for the engine will be stamped on the lug / hook moulded / cast into the cylinder head by the Tbelt cover on original engines
replacement engines may be blank
VCDS will look at the VIN and pick the engine most of the time or pick from the label file if it can not get the VIN on early pre can cars , can began in earnest in 2001 in the Passat.
my Audi A4q with AEB does about 34 mpg at about 65 mph with AC on
my Passat ATQ does about 32 mpg same conditions
but mostly i use
the geo metro
Last edited by mwebb; 03-03-2012 at 02:03 AM.. Reason: water on the comfort module harness can be easily repaired
