A well designed warm air intake is sized for the engine and cruising RPM and then it takes air that has been heated by the exhaust, there is enough air flow in the engine compartment that it's not much warmer then what you see from a "cold" air intake, but if you duct 100 degree air from near the exhaust, you see an improvement.
