MAF Reading
Hi All,
I'm modifying OBDuino to utilise a protocol from Nissan (Consult II).
In doing so, I've found that the g/s MAF reading is not available - I get a V reading instead.
Any thoughts if I can use the V reading someway (i.e. scale the reading to equal a g/s rate)?
Or if not, I can get injector pulse rate - how would that fit in a calculation? Injector duty would show how long each is open for, knowing the flow rate of the injectors - wouldn't it be possible to know how much fuel is going in? Would that be less accurate than the MAF method?
I don't have MAP accessible as a parameter either - the MAF sensor is there - but doesn't appear to be via the data reading.
