mechman is correct. A DPF is for particualtes, while SCR is for NOx.
Here's my attempt at a quick summary. Diesel emissions mainly come down to NOx and particulates (PM).
PM can be controlled somewhat by changes to the engine itself, but in order to meet modern on-highway regs, it's almost always necessary to have a DPF to clean up the PM after it comes out of the engine.
NOx can be controlled on-engine by using EGR, which can get the levels low, but only to a point. If EGR alone isn't good enough, then the NOx has to be taken care of in the tailpipe either by SCR or a NOx adsorber (aka lean NOx trap). The SCR is extremely effective (95%+ reduction in NOx), but it requires the use of urea, aka diesel exhaust fluid (DEF) and is more expensive and bulkier than a less-effective NOx adsorber.
Different configurations make sense for different applications with different regs. I've seen all the following (for current regs):
1) EGR & DPF
2) SCR only
3) SCR & DPF
4) EGR, SCR, & DPF
5) EGR, NOx adsorber, & DPF
I don't know of any vehicles out there that meet the 2010 North American emissions regs with option 2. I know there are some Euro5 applications that use option 2, but I doubt anybody will make it work for Euro6. Option 1 is getting very difficult to do as well. I think Navistar is the only one using this for 2010+.
Keep in mind that all of these give a different tradeoff between fuel economy, initial cost, & DEF usage. Fluctuating fuel and/or DEF prices also affect which option makes the most sense. For example, SCR gives better fuel economy than EGR, but requires DEF usage--so if fuel is "cheap" EGR may make sense, while high fuel prices make SCR more attractive.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
