Old 03-05-2012, 08:05 PM   #8 (permalink)
1carnut
Sparky - '07 Toyota Prius Base
Voltage_kwh - '18 Chevy Volt LT
90 day: 151.04 mpg (US)
Voltage_gas - '18 Chevy Volt LT
90 day: 43.38 mpg (US)
Unplugged O2 sensor and took a test drive and let it get warmed up. Gentle gas pedal stumble was gone but the bouncing idle still remained. So I guess I have multiple issues. I will go through the other suggestions when I have time to try to figure out what else is going on but I'm assuming that I will have to replace the O2. That was all I had time to check tonight. Thanks again for all of the info. I will post further results when I have them in order to benefit others.
