I managed to get the 3800 out of the Oldsmobile today. That baby is heavy! I bet it weighs almost as much as the 2.2 AND tranny put together.
I will be putting new gaskets in it and fixing anything that needs to be fixed and then bolting it to the 4t40. The 4t40 is a lot smaller than the 4t60, but is supposed to be pretty tough. I have seen really tuned up motors bolted to the 4t40, so it should be good to go.
I am pretty sure both cars used the same converter.
I also removed the exhaust from the olds. It was fairly easy and I am glad it is done. It will get cut and welded to fit the sunfire, and the sunfire exhaust will come out with a sawzall.
I have been messing with the idea of putting the 2.2 in my john deere M since it only has 20 HP and could use some GIDDY-UP!!!
Bolting on another 100 horses should be fun right?
Pics will be up tomorrow, I'm tired.
