Old 03-06-2012, 10:45 AM   #780 (permalink)
eimix
- When a car runs on LPG where are the data?
What data? car running on LPG is same as gasoline - just different mass/volume ratio and different air/fuel ratio - two constants are in *.pde file.
- Whether in the code to make the transition: ...
In "code" car is always running on gasoline or on LPG. No transitions.
Running on gasoline is for such short time - that it does not make big error.
No data from LPG ECU is taken.
Consumption calculation are same, just used different constants.
Injectors time are not used for calculations in gasoline mode, so why they should be used in LPG mode?
In this OBDuino - only speed, rpm, maf or map is used from car ECU via OBD2.
