Old 03-06-2012, 10:26 AM   #5 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by Bobux View Post
... is equipped with a 12-liter V8 engine, naturally aspirated direct injection diesel. Compression ratio of 16.5, OHV, peak torque 550Nm @ 1200RPM, peak power 180hp @ 2000RPM. Engine is free-flow: no intake restrictions, no turbo, no catalyst.
Sounds like you're dealing with a dinosaur. In my opinion, you'd be miles ahead by swaping to a much smaller modern turbodiesel, rather than trying to modify the existing engine.
Consider the fact that you can get a EuroV Cummins ISB 4.5L engine (4 cylinder version of the 6 cyle 6.7L engine that I have in my truck) with the following specs:
Peak torque=760 Nm @ 1400rpm
Peak power=204 hp @ 2300 rpm
Thats more power and toque from an engine with under 40% the displacement. That particular engine is also sold with a single turbo and no EGR. The EuroV engine is sold with an SCR cataylst.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
