Old 03-06-2012, 12:20 PM   #127 (permalink)
jkv357
Originally Posted by low&slow View Post
Hi Jay, Yes, regular old tech roller chain. Are o-ring chains supposed to be more efficient ? I'll check it out, thanks.
A regular old non-O-ring is more efficient because it doesn't have the seals creating friction.
An O-ring chain will live longer because it's sealed - keeping grease in and dirt out.
If you keep a standard one adjusted and lubed and it will be fine, plus reduce rolling resistance from friction. I would think you would want to run the tension on the loose side, but still reasonable.
Jay
