Old 03-06-2012, 07:41 PM   #7 (permalink)
EF TuneRR
The DX - '91 Honda CRX DX
Last 3: 33.49 mpg (US)
The Race Car - '91 Honda CRX Si
90 day: 28.35 mpg (US)
The DX v2.0 - '91 Honda CRX DX
Last 3: 35.11 mpg (US)
DX v3 - '91 Honda CRX DX
Originally Posted by Ryland View Post
I would balance everything so it runs as smooth as possible.
The VX fly wheel is already lighter weight then other models.
Indexed NGK V-power spark plugs once it's all together.
I'm pretty sure the above comment about the flywheel was meant towards an after market light weight flywheel. I'd look into a 7.5-lb Fidanza flywheel.
Anything the removes rotating mass. Lightweight connecting rods and pistons. Have the entire rotating assembly blueprinted and balanced. Also, maybe look into knife-edging your crank.
Honestly, learning to drive the car and learning/changing your driving style will probably be more cost effective than spending the money "building" the engine. Plus, your car won't have any down-time so you can enjoy it. I'm not saying DON'T build it, but maybe hold off on doing it for a while.
