Will an almost ground-scrappin air dam and splitter reduce drag?
It is clear that a low ground clearance airdam and splitter would create downforce (or at least reduce high speed lift).
But would it also reduce reduce drag?
The dam would increase front area (thus potentially increasing drag) but would the reduced underbody flow compensate for this area increase to reduce overall drag?
