I think that by leaving the two rear wheel fenders as large and square (all are flat and a couple are rising) then there will be two fairly large turbulent wakes instead of one larger one. Plan taper and top taper would do more to reduce wake drag than the channel in the middle, I think.
Ignoring the exhaust system, you can't beat this rear end:
Here's one closer to what you may be going for?
