Old 03-07-2012, 12:08 AM   #44 (permalink)
slowmover
90 day: 19.36 mpg (US)
Diesel exhaust system
When I bought my truck the PO had removed the stock muffler and tailpipe and replaced it with an:
- Aeroturbine 4040
but the drone while towing was unreal. Had to almost (literally) yell for my wife to hear me. After reading some threads on TDR I copied the move made by several by moving the A-T forward to serve as resonator and added a
- ROKKTECH Silent Might
which has to be the best sounding muffler ever made for an ISB Cummins. Straight-thru but for 3-square holes cut at one end (large chamber surrounding pipe) in the direction indicated for "quiet" (on a quiet muffler).
The section cut out was used to replace a gaudy tailpipe tip (extends exhaust out past rocker panel several inches. Definitely a school bus look).
The exhaust system is essentially a 3.5" i.d. pipe with [2] 4" i.d. pipe mufflers.
Is it better than stock? Maybe, maybe not. But it is lower backpressure I'm fairly sure and just about as quiet but with a different sound (sharper) than the stock system.
I've thought about playing with it by adding an EAG at the mouth of the A-T as a few reports indicate better steady-state fuel burn.
