Old 03-07-2012, 03:08 AM   #6 (permalink)
Bobux
More compression is better.
Good to know, thanks
Water mist injection would help some.
I guess this only applies to forced-induction engines because intake temperatures are higher even after an intercooler.
EGR and catalyst hurt fuel economy.
EGR only helps by warming up the engine faster, beyond that its no good.
Again, good to know, thanks
By far the best thing you could do is stick a turbocharger on there
A turbocharger would definitely improve engine characteristics in means of power, it was the first idea that came into my mind when I thought of engine tune-up. But in this case I'd like to focus on fuel efficiency rather then on power (it does not mean I am willing to sacrifice any, it's just not a #1 priority). I guess a turbocharger will not help efficiency much, right?
Originally Posted by Diesel_Dave View Post
Sounds like you're dealing with a dinosaur.
As said before, it's a military vehicle, it was designed that way. Take a look at HMMWVs - they output 190hp out of 6.5l AFTER turbocharging, and don't have too much torque either. These engines were meant to work with sand in the intake, water in fuel and 1/3 of oil they usually run with... So, it's not the age we are dealing with.
It's fairly obvious that fitting in a complete modern engine will get the best results. I was just wondering why this particular engine consumed that much and what the consumption would be with a different engine.
