Thread
Purchasing an MPGuino
03-07-2012, 09:26 AM
11
permalink
gone.g
If anybody feels like going through these to tell me if there right or wrong to build a MPGuino that would be wonderful
RJ11 -
50 x RJ11 Modular Network PCB Jack Connector 5222 6P6C | eBay
50x LCD -
HD44780 16x2 LCD module Blue backlight+Free pin header | eBay
ATMega chip -
50PCS IC ATMEGA8-16PU ATMEL DIP-28 NEW GOOD QUALITY | eBay
switch -
300PCS 6*6MM 6.5MM TACT SWITCH TACTILE PUSH BUTTON | eBay
usb -
50 pcs USB-B Type Right Angle PCB Socket Female Connector New | eBay
470uf capacitor -
50 x 470uF 25V Radial Electrolytic Capacitor 8 x 12 mm | eBay
transistor -
50pcs MMBT3906 /PMBT3906/2N3906 TRANSISTOR GP PNP AMP SOT-23 | eBay
diode -
!! 100pcs 1N4004 400V 1A Rectifier Diode DO-41 | eBay
oscillator -
50pcs 16MHZ 16 MHZ 16M HZ Crystal Oscillator HC-49S NEW | eBay
0.1uf capacitor-
200pcs 0.1uF 50V Ceramic Disc Capacitors | eBay
18pf capacitor -
50 Pcs 18pF 50V 20% 2mm Pitch Ceramic Disc Capacitors | eBay
1.2k resistor -
100 x Resistors 1.2K ohm 1K2 1/4W 250V 5% Carbon Film - Free Shipping | eBay
100k resistor -
100 x Resistors 100K ohm 1/4W 250V 5% Carbon Film-Free Shipping | eBay
L7805 regulator -
50 x L7805 7805 Voltage Regulator 5V 1.5A SGS-THOMSON - Free Shipping | eBay
28pin socket -
50pcs 28 pin 28pin DIP IC sockets Adaptor Solder Type | eBay
zener diode -
Through Hole Zener Diode 1/2W DC 5.1V Voltage Regulator | eBay
10k resistor -
10K
220 resistor -
50 x Through Hole Carbon Film Resistor 1/4W 250V 220 ohm | eBay
50x atmega board -
1x Freeduino Arduino atmega168 Development Board PCB | eBay
only thing missing *i think possibly others* is the 'smaller capacitor... i have no idea what type that should be the yellow one that is
gone.g
View Public Profile
Send a private message to gone.g
Find More Posts by gone.g
