Old 03-07-2012, 10:31 AM   #11 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by Old Mechanic View Post
Heed the warnings about pouring diesel in a gas tank or vice versa. Mercedes recommended adding gasoline to diesel fuel for extreme cold temp operation, but there was a big highlighted warning about pouring one into the other. I think it was diesel in a gas tank but this is ancient memory (1982). The were very adamant about the danger., and I think it is what you are doing (diesel in a gas tank).
regards
Mech
I'm with Old Mechanic, I wrote this in another thread last year:
I have another reason I'm not going to mix diesel into my gas tank. For a sealed tank, like a gas tank in a car, if there is any liquid fuel present the high partial pressure of gasoline saturates the vapor volume of the container. The saturated vapor is too rich to burn (above the upper explosive limit, UEL). Essentially a sealed gas tank with gas in it is safe. A diesel tank is also safe, but diesel has such a low vapor pressure the vapor is too lean to burn (below the lower explosive limit, LEL). But a mixture of the 2, for a wide range of concentrations of gasoline and diesel, allows explosive mixtures in the vapor volume of the canister. For extreme concentrations the mixture is safe, but at about 5% diesel the amount of gasoline that evaporates into a closed container drops below its UEL, and above about 50% diesel - 50% gasoline, the diesel vapor concentration rises above its LEL. A bad idea to mix in the same tank.
-mort
