Old 03-07-2012, 09:27 PM   #141 (permalink)
redyaris
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
[QUOTE=low&slow;291833]
Originally Posted by beatr911 View Post
The taller gearing has magnified poor part throttle response; I need to clean, check and adjust my carbs to hopefully correct this.
I too have had part throatle problems with the GS500 in sixth gear. What I suspect is, that when the GS500 engine is at 3500rpm or lower in sixth gear,
the carb. may be running on the off idle cucuit, because the throatle is almost closed. This cucuit is for first gear starting and is not all that good for sixth gear...
You may be having the same problem. What I have desided to do is optimise the final drive to keep the GS500 above 3500rpm, in 6th gear, at highway speed of 65 - 70mph, until I can come up with a better solution. I am day dreaming about a single carb setup with my own intake manifold.
