[QUOTE=redyaris;291991]
Originally Posted by low&slow
I am day dreaming about a single carb setup with my own intake manifold.
Yes, this is the answer. As we all know, multiple carbs are tuned for power not economy. By going to a single throttle valve, you can run at a larger throttle opening and lower the amount of "negative work" the engine has to do as well.
Mike
