Welcome, and thanks for welcoming others! I am a big Honda fan, treasure my
'87 CRX, 62.9 best mpg. so far; only mods: pass seat out, tires bumped up, and nut adjusted behind the wheel.
Generally, prefer Honda motorcycles as well.
Don't be afraid to bump tire psi at least 7 beyond max sidewall rating.
That might be a good stopping point to gauge desired ride quality, and shouldn't
create faster wear.
Just keep the extra psi in mind if you are used to flying around corners in the rain.
Obviously, you wouldn't want to be going 10/10ths there!
Nice rides you have/have had!
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
