Originally Posted by marcexec
I have been following the Raspberry Pi project.
I wouldn't use it for the master board, it would only be possible to use it for display purposes, logging, connectivity etc. which means one level higher.
sudo bmsmaster --restart --force anyone?
I have the same opinion, no need of this king of board and operating system for the master board, which need to startup instantaneously when ignition turn ON. I use embedded linux on a lot of project, but I don't see the advantage here.
I'd prefer ATMEL or PIC, maybe an Arduino that you can interface to with whatever you want.
This is just my opinion, of course - what do you think?
Anyway, at my opinion there is absolutely no need to choose the microcontroller or other component now, the important step is to validate the general architecture of the board, to decide which functions the board must implement or not. The microcontroller choice is almost the last step
I need to add on my general architecture image that the digital outputs must have the PWM capability.
