I used my math 102 class today to do a series of voltage, current and rpm measurements on a DC motor. the results:
if voltage is fixed, the amp-rpm curve is linear. for different voltages, the amp-rpm curves are parallel. So, you just need 2 of 3 volts, amps, and rpm to know the other one.
