Old 03-09-2012, 12:09 PM   #22 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
This is interesting. Is this another acetone rabbit trail or real? Anyone do ABA testing?
Since diesel has a slightly higher btu content, is this the reason for the power and economy gains you all are seeing?
For those that are adding diesel to gasoline:
1) What are the mix ratios you are using?
2) What are the gains in measured mpg you are seeing with those ratios?
For me, I add about 1oz/gallon or about 1:132 of filtered (<1 micron) used engine oil to my fuel. Have been for over 6 years now. It doesn't cost $4/gallon, it's free.
Effects: No measurable effect on MPG but it uses most of my drain oil up between changes. My truck is really sensitive and wants mid-grade most of the time anyway so the increased suseptibility to knock is not tolerable. The Kawasaki tolerates it even with a 4* ignition advance, has very slight ash deposits on the plug. The Odyssey doesn't bat an eye. The 2011 Dodge Caravan for my vanpool doesn't care.
Good design is simple. Getting there isn't.
