Originally Posted by mwebb
there will not be spark at both electrodes , the spark will take the single easiest pathway to ground , which may vary as the gap erodes and conditions inside the combustion chamber change .
Yep. If you really want to have two sparks, use two plugs. Chrysler's Hemis have two plugs per cylinder. If it were really a unicorn then they'd advertise the extra plugs to get some benefit from it. I think that the head design has a lot to do with any gain from it because they don't use it in other engines.
never use... they were never OEM specified for any system and do not perform as well as the correct OEM specified part# for the system in question
That sums it all up nicely. It's always my recommendation with spark plugs.
