Old 03-09-2012, 02:43 PM   #26 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
Well, hey. Since my truck is lightly pinging under any sort of load, and it seems to be much better with mid-grade, it should be a good test bed for this octane theory. It doesn't have a knock sensor so it should give a good, audible indicator if it boosts octane or not.
I don't drive it much so please don't expect my results anytime soon.
Someone with a scangauge could also record the RPM, LOD and IGN values at several points and log ABA values for each. With higher octane, newer engines should advance the ignition a degree or two for a given LOD and RPM.
Good design is simple. Getting there isn't.
