Old 03-10-2012, 09:10 PM   #13 (permalink)
Grant-53
The shear strength on the 4mm x 18mm area will depend on the material of the cog. Would it be possible to put a steel sleeve over the outside of both the cog and motor shaft then use four 6mm set screws to hold it in place?
Any improvements in aerodynamics will reduce power requirements.
