stomper Quote I drive about 60+ miles a day i carry yard equipment every day, push mower, weedeater, blower, gas can, rake, etc. I need all this stuff everyday so i cant get rid of it, would a rolling tonneau cover help?
If your handy you can...
- Buy a civic vx hatchback. It already has a tailgate
- Cut off the roof behind the "cab"
- At this point might as well cut out the window area above the quarter panels
- Weld in some sort of floor and cap off your "pickup box side rails"
- Build a fiberglass/foam aeroshell to use when your not using your vehicle as a real truck.This will weight at most 30 lbs so you can put it on/off by yourself.
- Brag to your friends about your truck that gets 50 mpg with the shell off and 60 mpg with it on
Of course I am joking except for #1 above ....But then again I really want someone to do this so I don't have to. Hell I bet you could even beat those old diesel Vw pickups for the 1980's
