The communication protocol between master and slave board is finished and work perfectly on the entire temperature range of the microcontroller, even at -40°c
With the auto baud rate configuration on each first byte of the protocol frame, the baudrate always stays below 1% error even with the max +/-6% deviation of the internal clock of the microcontroller.
