Old 03-11-2012, 01:48 PM   #27 (permalink)
Superdutytd
I should have done some research, this stuff is cheap, haha so even if I mess up it wouldn't be an expensive mistake. Thanks for the heads up, for some reason I had figured it would be much more expensive. Do you happen to have any larger close up pics? Mostly of the crossmember and where/how they tie in? This is of course unless you want to remain unique with your design! Haha thanks a lot for the information again.
