Welcome! Ditto to Mcrew's psi advice. Maybe you could inform use as generally; how much rural, urban, suburban, etc.. is your driving?
Are you willing to use routes that may be slightly longer to stay away from multiple red lights, and courses that keep your average cruising speed lower, and fairly constant?
The beauty is that the most gains don't have to be big body mods. The area between
your ears, is really where you can have the greatest effect. Smoothness, finesse, behind the wheel is key.
Grille blocks, and partial outer mirror size reduction, a front airdam; might be fun projects
to digest one at a time, without changing the veh. drastically, or weirding out the family!
Pick a spot to dig in at your comfort level.
Hope to read in other sections, updates of progress as you go along.
Keep asking questions, and don't be afraid to dig into older pages.
The only dumb question one can ask, is if that question has already been addressed
in older threads.
Again; welcome!
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
