hi thought id post this for all you guys thats have a new body style firefly with rough looking rockers. i cut out the rusted spots and made an entire rocker panel to fit over what was left of the tin. i used por15 to paint the inside tin then glued the rocker panel on with body shop eurathan, held on with clamps but wasnt realy needed as the peice was a perfect fit and the eurathan is so thick once i pressed the rocker on i could hardly move it. Also i added some pics of the mods ive done im getting around 60-65 mpg on the highway. side view mirror delete, blocked grill, space saver tires on the rear, i was so impressed with the gas mpg change with this mod that i kept them on, ive had them on for 4000 kms and no sign of wear on them. also i pick these wheels up at the auto wrecker for 10$ each, and did wheel skirts for less rear wheel well bumper drag and to hide the spare tires
