Old 03-12-2012, 12:14 AM   #174 (permalink)
Grant-53
Use the 5:1 airfoil and a 25% kamm cut as the beltline (X-Z plane). Curve to the top and bottom using ellipsoids. Use the 3D graph option on a spreadsheet to match your bike dimensions. Max width between the the handle bars and the shoulders. The rounded shapes will reduce wind loading and could generate a bit of down force if the minor axis of the lower part is greater than the top part. If max width is 24 inches then overall length is 90 inches.
The Following User Says Thank You to Grant-53 For This Useful Post:
renault_megane_dci (07-10-2012)
