Old 03-12-2012, 12:14 AM   #3 (permalink)
Grant-53
The best thing is to first check the manufacturers' websites. They can tell specifications and whether the parts are still available. Once you have some model numbers you can search the web for reviews. With any machine consider where and when will you use it. What might be the average annual costs over the expected life of the unit? Do you ride on dirt or pavement? Do you use panniers or a trailer? Is the steering geometry very responsive or laid back? Will you have to rebuild the wheel to use the hub? Is the gearing right for you if you need to ride home on a low battery? Does the controller allow for regenetive or dynamic braking? Is there enough room on the handle bars for everything to fit comfortably? How will you charge the batteries between trips? What state laws apply to your vehicle? I don't mean to be a bore but you will come out ahead if you do some homework first. Any fairing or streamlining you can do will improve your range. Enjoy!
