Old 03-12-2012, 12:42 AM   #20 (permalink)
drmiller100
Originally Posted by Diesel_Dave View Post
So with the turbo, the lower speed means lower friction losses & lower pumping losses. The heat loss to the cylinder walls should also be less because the ratio of fuel burned to surface area has increased.
you pump three times the air, you have 3 times the pumping losses with a diesel.
friction is mouse nuts in terms of efficiency (mouse nuts are so small as to be really hard to measure).
Diesels have a slow burn rate, so they can't turn high RPM. To make a diesel compete with a gasoline engine, the only way to keep the weight of the engine similar is to put a turbo on the diesel.
