Old 03-12-2012, 05:43 AM   #2 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Narrower? No. Taller, yes!
What you want to do is put on the largest load carrying capacity tire that will fit without rubbing. Bigger is better! It's a small change and the difference between tires (meaning make and model) is much, much larger, so that is a more important consideration.
