The equation is simple: terrain dictates. What works best at one spot today might not be the best in the same spot tomorrow. I find that EOC from 70 to 20 works wonders for me... when there's a tollbooth in my future. Except that one of them is best hit from 60. Usually. Only one of my four tollbooth glides has a clearly defined start point, and even that doesn't have a clearly defined starting speed.
A good rule is to never go faster than you have to, and experiment to find out if starting a particular glide from a higher speed pays off by getting you farther enough to matter. Ain't hypermiling fun?
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
