Old 03-12-2012, 01:58 PM   #3 (permalink)
roosterk0031
Leaving both valves open would pump oxygen into the exhaust stream and mess with O2 sensor.
I think just leaving intake valves open would work better, if they deativated the same 2 cylinders all the time and the pistons are 180 off each other I wonder about connecting the intake runners between them to push the air back and forth between the 2 cylinders.
