Old 03-12-2012, 11:35 PM   #35 (permalink)
bandit86
Buggie - '01 Vw Beetle TDI Gls
you will not see any perfomance increase, worse you will see a loss if your ignition is not adjusted for premium fuel. it burns at a slower rate, if your ignition timing remains constant then the fuel will completely burn when the cylinder is already past TDC. My truck is set to run on premium, regular burns too quick and causes power loss and efficiency.
